Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
O que você precisa
In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 outras pessoas executaram este guia.
2 comentários
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
