Ir para o conteúdo principal
How to clean Microtek ScanMaker 5900 surface glass
O que você precisa
  1. How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, imagem 1 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, imagem 2 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, imagem 3 %32
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, imagem 1 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, imagem 2 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, imagem 3 %32
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. How to clean Microtek ScanMaker 5900 surface glass, How to clean Microtek ScanMaker 5900 surface glass: passo 3, imagem 1 %32
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints, and other debris.
Conclusão
Equipe
Cal Poly, Team 6-9, Regan Fall 2011 Membro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,980
