Ir para o conteúdo principal
How to clean Game Boy Advance buttons
O que você precisa
  1. How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: passo 1, imagem 1 %32 How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: passo 1, imagem 2 %32
    • Use a slightly damp toothbrush to scrape in between the desired sticky buttons. You can also use a bit of isopropyl alcohol.
    • Make sure toothbrush is not to the point of dripping water when scraping.
  2. How to clean Game Boy Advance buttons: passo 2, imagem 1 %32
    • Dry with a cloth after the sticky residue is removed.
Linha de Chegada
9 outras pessoas executaram este guia.
Adam
Membro desde: 01/20/10
807 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 16-29, Maness Winter 2010 Membro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
Membros da 5
Autoria de 61 guias
3 comentários
I just used this method to clean sticky buttons on a wireless Xbox 360 controller. The Back, Xbox Guide, Start, X, Y, B, and A buttons were all sticky and unresponsive.
I removed the battery pack and followed the steps, and it worked like a charm. All of the buttons work just fine now except for the Xbox Guide button, which isn't really a big deal anyway.
This method works great. Thanks for making this guide, Adam.
Jeff Laxson - Responder
Wow. I thought I was going to have to buy a new Wii U Pro Controller, but this fixed my sticky B button. So simple. Thanks for saving me $50, friend.
Trevor Babcock - Responder
my d-pad needs cleaning, help?
Trace Ruby - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 76
Duração total: 27,326
