Ir para o conteúdo principal
How to clean Canon PowerShot A550 buttons
O que você precisa
  1. How to clean Canon PowerShot A550 buttons, Front and Back Covers: passo 1, imagem 1 %32 How to clean Canon PowerShot A550 buttons, Front and Back Covers: passo 1, imagem 2 %32 How to clean Canon PowerShot A550 buttons, Front and Back Covers: passo 1, imagem 3 %32
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. How to clean Canon PowerShot A550 buttons: passo 2, imagem 1 %32
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. How to clean Canon PowerShot A550 buttons: passo 3, imagem 1 %32
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. How to clean Canon PowerShot A550 buttons: passo 4, imagem 1 %32 How to clean Canon PowerShot A550 buttons: passo 4, imagem 2 %32
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. How to clean Canon PowerShot A550 buttons: passo 5, imagem 1 %32
    • The camera should look like this once the front cover is removed.
  6. How to clean Canon PowerShot A550 buttons: passo 6, imagem 1 %32 How to clean Canon PowerShot A550 buttons: passo 6, imagem 2 %32 How to clean Canon PowerShot A550 buttons: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. How to clean Canon PowerShot A550 buttons: passo 7, imagem 1 %32
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. How to clean Canon PowerShot A550 buttons, How to clean Canon PowerShot A550 buttons: passo 8, imagem 1 %32
    • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
Conclusão
Shaelyn Thomas
Membro desde: 04/19/11
392 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-6, Regan Spring 2011 Membro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membros
Autoria de 22 guias
1Comentário do guia
new Battery in side & massages is Battery low why?
Rupesh Jamsandekar - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 2,167
