Introdução
This guide will teach you how to clean your EarPods
O que você precisa
If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
Use a toothpick to rub all the holes in the earphone
using toothpick can push the wax further into the wire mesh...Tried and repenting!
if this has happened with anybody, use toothbrush or wall paint brush...and do a "soft-jab and sweep"
What do you do when you do push the wax inside? I think I pushed a substantial amount in.
Toothbrush works so much better, fast and easy. My EarPods sound like new so much it startled me.
Alcohol induced corrosion? Really?
Think again
I don't think it said that
Corrosion is possible... and more than likely. Most alcohol is not sold as 100% alcohol. It is almost always mixed in a solution with water
tucker28 -
Remember to dry your Earpods for 10 minutes.
85 outras pessoas executaram este guia.
31 comentários
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
With saliva? You &&^&^$ disgusting.
GROSS Saliva? yuck
what the &&^& is wrong with you
Consider using ACV (vinegar).
All I do is use disinfecting wipes and I home free!!!
doesn't enough for my earphone
i used sticky tac to pull the excess wax out of the grill it made the grills on my earpods look like new
This is genius
Watch this video & clean your EarPods effectively - https://www.youtube.com/watch?v=aH-qrqao...
I just discovered that using an earplug (y'know, the kind that you use to reduce noise) to clean my earpods is a great solution! They're made of super soft foam to conform to the small nooks/crannies of earpods and it expands back to it's regular form for next-time use. Haven't seen anything on the web about this technique - so, i thought i'd place it here.
Help! i don’t have that rubbing alcohol and i don’t know where to find it. is it fine if i just use water?
My headphones were so bad. I didn’t have a tooth pick but i had a needle. I carefully scrapped away all the wax then dipped my finger in rubbing alcohol and lightly tapped my finger on the speaker, then i got a q tip and rubbed it on it. I reapeted this untill it was all clean. Before all this on the right one you could only hear out of the small side speaker but now you can clearly hear out of it. I migh post a video on youtube!
RIP THE GRILL OUT. It saves a TON of time, and they almost never need to get cleaned again. It sounds like you will destroy them, but you won’t if you’re careful. I actually do this by jamming a Nintendo DS stylus or mechanical pencil through the grill, rotating it to the side, and using the stylus as a lever to rip it out.. There’s a white support in the center that normally prevents the grill from entering the EarPod. Try not to break it, but it doesn’t matter if you do, just angle it inward so it doesn’t poke your ear. The sound is actually better and clearer after the grill is gone. I have done this to my last 2-3 pairs of EarPods and it’s honestly the only way I’ll use them. When my cat chews through a pair, I buy/find (people lose the things all the time on the ground at my school) another set and immediately rip the grill out. I’ve never broken a pair by doing this, and when I eventually get AirPods, I will be doing this to those as well. Do it, you won’t be disappointed.
Kelebihan Apple Earpod dari pada ear piece merek lain http://zapplerepair.com/kelebihan-Apple-...
None of this worked. I STILL have no sound in the left earphone. Highly disappointed.
It is possible that the speaker or wire itself is damaged. Just like with lightning cords, they are fragile and are prone to breaking easier than others.
Once I unintentionally left my EarPods in my jacket pocket. Jacket went to the washing machine. And surprisingly, EarPods were not damaged at all and got out like new. I did it again and same all clean and working fine. I would not recommend it though as from my knowledge it mus damage the metal parts in it, especially with the ones with lightning connector. I guess the best would be an ultrasonic bath.
What about the volume switch? I opened mine up but can’t close it again
I used rubbing alcohol to clean cord on Earbuds and it does the job!
