Ir para o conteúdo principal
How to clean Apple EarPods
O que você precisa
  1. How to clean Apple EarPods, Apple EarPods cleaning: passo 1, imagem 1 %32
    • If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
  2. How to clean Apple EarPods: passo 2, imagem 1 %32 How to clean Apple EarPods: passo 2, imagem 2 %32
    • Use a toothpick to rub all the holes in the earphone
    • Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
  3. How to clean Apple EarPods: passo 3, imagem 1 %32 How to clean Apple EarPods: passo 3, imagem 2 %32
    • Repeat the process for the other EarPod
  4. How to clean Apple EarPods: passo 4, imagem 1 %32 How to clean Apple EarPods: passo 4, imagem 2 %32
    • Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod
    • Ignore the fact that the alcohol is in the Earpods' case
  5. How to clean Apple EarPods: passo 5, imagem 1 %32 How to clean Apple EarPods: passo 5, imagem 2 %32
    • Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
  6. How to clean Apple EarPods: passo 6, imagem 1 %32
    • Let the EarPods dry for at least 10 minutes before using
    • Let the Earpods dry by itself, if you use a fan, a hair dryer, or anything else, you could generate corrosion inside and that will ruin it
Conclusão
Remember to dry your Earpods for 10 minutes.
85 outras pessoas executaram este guia.
jimenezser
Membro desde: 08/29/12
3.848 Reputação
Autoria de 4 guias
31 comentários
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
jaidityayadav - Responder
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
allisonbridges1 - Responder
With saliva? You &&^&^$ disgusting.
Pixel Shibe -
GROSS Saliva? yuck
adrienne adams -
what the &&^& is wrong with you
fisheruwu edits -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 55
Últimos 30 dias: 280
Duração total: 407,656
