Pular para o conteúdo principal
Introdução
Checking the battery is fairly easy, all you will need is a multimeter, which can be purchased at a local hardware store.
  1. Slide the battery cover up and off the phone. Slide the battery cover up and off the phone.
    • Slide the battery cover up and off the phone.
  2. Pop the battery out of its slot by lifting it up. Pop the battery out of its slot by lifting it up.
    • Pop the battery out of its slot by lifting it up.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  4. Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV. Turn the multimeter on.
    • Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV.
    • Turn the multimeter on.
  5. Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
    • Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
    • Replace the battery if the voltage reads below 2.5 volts.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Waltman
Membro desde: 14-01-2011
111 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-10, Forte Winter 2011 Membro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membros
16 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Todo: 4,931
