O que você precisa
Grab wegdge with tweezers
Loosen the screw. (while holding the wedge)
Put the wedge in the tranducer from below.
Correct Placement. Tool is flush with transducer.
Incorrect Placement. tool is too high.
Fasten the screw lightly
Tighten the screw just so the wedge does not slip out of the tranducer.
Place gauge below Tool
Loosen the screw so the wedge slides onto the gauge Lever.
Lift the gauge up until in contact with the transducer horn.
Now the Tool-Top should be flush with the Transducer-Horn
Tighten the screw with the torque- wrench
Use tweezers to push the wire down the wire hole, until it Ends some cm below the tool wedge.
Use scissors to cut the (contaminated) Wire down to a length of about 1cm below wedge end.
Use tweezers to thread the wire through the hole at the end of the wedge.
Afet threading pull the wire some cm through the hole.
