Introdução
One of the first things that you should do when you first start up Kali Linux is to change your systems default root password. Assuming that this is a fresh image, the systems password will be set to 'kali'
Press Ctrl + Alt + T to open the Terminal Interface.
Use the command sudo passwd root
When prompted enter your systems root command. If this is a fresh install of Kali, the default password will be set to 'kali'
The passwd command can be used to change any user account password that is set up in Kali regardless of if they're a root account or not.
12 outras pessoas executaram este guia.
