Ir para o conteúdo principal
How to apply scratch-proof coating
O que você precisa
  1. How to apply scratch-proof coating, How to apply scratch-proof coating: passo 1, imagem 1 %32
    • Use Liquid Sapphire scratch proof nanotechnology coating
  2. How to apply scratch-proof coating: passo 2, imagem 1 %32
    • Add 3 drops of Liquid Sapphire to the LCD
  3. How to apply scratch-proof coating: passo 3, imagem 1 %32
    • With a microfibre cloth wipe up and down until the LCD surface is covered.
  4. How to apply scratch-proof coating: passo 4, imagem 1 %32
    • keep wiping up and down until a Grey/White coat starts forming, it will look similar to a widow smear.
  5. How to apply scratch-proof coating: passo 5, imagem 1 %32
    • Leave to dry for 10 minuets and then buff off with a shammy (Chamois) Repeat the steps 3 times in total. The device can be used immediately. Keep clear of any objects that might scratch your screen until fully cured, in 24hrs.
    • Here is a coin scratching an iphone 5 LCD, watch and see what happens.
Conclusão
30 outras pessoas executaram este guia.
Irish Jack
Membro desde: 08/08/13
2.452 Reputação
Autoria de 1 guia
4 comentários
Dead product link
Jdwashere - Responder
Does this product/method work if you already have a couple of light scratches on the screen?
Thank you,
Gary
Gary Zehnpfennig - Responder
Does this product/method work if you already have a couple of light scratches on the screen.
Does this product/method work if you already have a couple of light scratches on the screen —
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 31
Duração total: 16,281
