Introdução
Anti-fingerprint oleophobic coating, applied to all Smartphones and Tablet PC touch screens, improves usability with scratch and water resistance. However, it tends to wear off, and may need to be reapplied.
Ferramentas
Não são necessárias ferramentas.
Peças
  1. Clean touch screen by microfiber cloth included in product package of Fusso SmartPhone.
    • Clean touch screen by microfiber cloth included in product package of Fusso SmartPhone.
  2. Drop the coating liquid ( 10-15drops) on the touch screen and coat the entire screen surface quickly before it dries. When applying to Tablet PCs, it's better to divide the screen area into 4 or 8 sections and coat each respective section of the touch screen area because the liquid dries very quickly. Liquid volume per area is the same as that for Smartphones. When applying to Tablet PCs, it's better to divide the screen area into 4 or 8 sections and coat each respective section of the touch screen area because the liquid dries very quickly. Liquid volume per area is the same as that for Smartphones.
    • Drop the coating liquid ( 10-15drops) on the touch screen and coat the entire screen surface quickly before it dries.
    • When applying to Tablet PCs, it's better to divide the screen area into 4 or 8 sections and coat each respective section of the touch screen area because the liquid dries very quickly. Liquid volume per area is the same as that for Smartphones.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Repeat step 2 two or three times and leave the device for 6-8 hrs without touching the screen surface. The coated film is then firmly bonded with the touch screen glass. Repeat step 2 two or three times and leave the device for 6-8 hrs without touching the screen surface. The coated film is then firmly bonded with the touch screen glass.
    • Repeat step 2 two or three times and leave the device for 6-8 hrs without touching the screen surface. The coated film is then firmly bonded with the touch screen glass.
  5. 2-3 COATS on different days to fully maximize Oleophobic performance and film durability is highly recommended. Remarks : Leftover residue on the touch screen after coating can be wiped off easily after 6-8hrs by using tissue paper. Please do not remove them before completion of film bonding. Remarks : Leftover residue on the touch screen after coating can be wiped off easily after 6-8hrs by using tissue paper. Please do not remove them before completion of film bonding.
    • 2-3 COATS on different days to fully maximize Oleophobic performance and film durability is highly recommended.
    • Remarks : Leftover residue on the touch screen after coating can be wiped off easily after 6-8hrs by using tissue paper. Please do not remove them before completion of film bonding.
  6. You can get Perfect Oleophobic Coating on your device !!
    • You can get Perfect Oleophobic Coating on your device !!
Linha de Chegada
112 outras pessoas concluíram este guia.
Ken Masaoka
3.970 reputação
Autoria de 1 guia
Very interesting guide. Awesome.
Do I have to remove the coating that is on the device when it's new?
Especially when the coating has some very small scratches?
And if yes, how to remove it?
Thanks
Peter Gordon - Responder
I recommend avoiding this for the iPhone 6. The curved screen simply directs the liquid into the casing.
Alex Pappajohn - Responder
Tried this with my iPhone 6. Seems to work pretty well. I'll do a few more quotes. I noticed this actually had a beneficial effect on screen scratches. Filled them in pretty well, blends with the screen more.
Talk about a happy accident!
ckeyser - Responder
one comment says not to use it with iPhone 6 and another one says it worked ok, so what do I do? is it any dangerous? because I bought it before your last comments but I still havent used it since I'm worried about what can happen
Salvador Martinez -
I always have problems with my screen, sometimes I can't see anything on my LCD.
Praska - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 82
Últimos 7 dias: 573
Últimos 30 dias: 3,068
Todo: 280,727
