Ir para o conteúdo principal
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: passo 1, imagem 1 %32 How to adjust Razor A steering column, How to adjust Razor A steering column: passo 1, imagem 2 %32
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: passo 2, imagem 1 %32
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Linha de Chegada
4 outras pessoas executaram este guia.
Jordyn
Membro desde: 10/09/12
544 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-13, Amido Fall 2012 Membro de Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
Membros da 4
Autoria de 10 guias
8 comentários
what move it with your hands? - didn't help
Heather McCasland - Responder
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Responder
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Responder
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Responder
My son just opened his brand new razor scooter and the head set is very loose. From past bicycle experience this will cause premature bearing failure and likely strip out the steering stem. This will in turn cost more to repair than it would be to replace the entire scooter. Are these headsets supposed to be loose from the factory?
mgenius33 - Responder
I can’t get it, gonna have to bring it in a bike shop for repair
Joe DeVito - Responder
Thank you so much! You made my day.
Ntro Nitro - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 40
Últimos 30 dias: 163
Duração total: 40,820
