Ir para o conteúdo principal
How to add a Smart Core to your phone.
  1. How to add a Smart Core to your phone., Case and Belt: passo 1, imagem 1 %32
    • First, insert the small blue cable in the box into the Core.
    • The end with the MicroUSB goes into the Core.
  2. How to add a Smart Core to your phone., Insertion into Smart Case: passo 2, imagem 1 %32 How to add a Smart Core to your phone., Insertion into Smart Case: passo 2, imagem 2 %32
    • Put the cable into its proper slot, in the bulge on the bottom of the case.
    • The Core is already connected, and goes with the cable fitting into the circular slot. (see second image)
  3. How to add a Smart Core to your phone., Phone Connection: passo 3, imagem 1 %32
    • Slide the bottom end of the phone 3/4 of the way in, from the top towards the bottom.
    • Continue sliding slowly. Make SURE the lightning connector on the cable connects to the phone.
    • The cable connector can sometimes slide under the phone. Avoid this.
  4. How to add a Smart Core to your phone., Final Build: passo 4, imagem 1 %32
    • Once the phone's bottom is flush with the case bottom, double check that the circle on the Core is lined up with the core on the case.
    • Now starting with the top corner without a camera, push it into the case.
    • Repeat step 2 with the top corner with a camera.
  5. How to add a Smart Core to your phone., Enjoy: passo 5, imagem 1 %32
    • Enjoy your great new case! Features:
    • Smart Battery
    • Military Grade Protection
    • Wireless Charging
    • Extra Storage*
    • * - Optional/Varies by model
    • External Drive*
    • Powerful LED Light Array
Conclusão
Enjoy!
9021007
Membro desde: 07/13/18
4.599 Reputação
Autoria de 25 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 526
