Ir para o conteúdo principal
How to access hidden settings on RCA RT2806
  1. How to access hidden settings on RCA RT2806, Power: passo 1, imagem 1 %32
    • Turn on your TV
  2. How to access hidden settings on RCA RT2806, Open the Menu: passo 2, imagem 1 %32 How to access hidden settings on RCA RT2806, Open the Menu: passo 2, imagem 2 %32
    • Open the menu, by pressing the menu button on the remote
  3. How to access hidden settings on RCA RT2806, NumPad Shortcut: passo 3, imagem 1 %32 How to access hidden settings on RCA RT2806, NumPad Shortcut: passo 3, imagem 2 %32
    • Press the following buttons quickly after opening the menu:
    • 1-1-4-7
    • This is a column of numbers on your NumPad
    • If it doesn't work, do it more quickly after opening the menu, and check your TV model number.
Conclusão
To close the new menu, press EXIT
9021007
Membro desde: 07/13/18
4.599 Reputação
Autoria de 25 guias
3 comentários
You can disable the dog logo on here under General Settings.
9021007 - Responder
Thank you very much. This was driving me insane
Will McCreary -
Is there any way to save settings? Some settings are permanent, but specifically the overscan settings are reset to their original values when I power the screen off, whether by the remote power button, the power button on the screen itself. or by unplugging it.
Please advise.
Jyri Keir - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 76
Duração total: 2,751
