Ir para o conteúdo principal
How to Wipe Samsung Galaxy S4 Data / Factory Reset
Vídeo de Apresentação
  1. How to Wipe Samsung Galaxy S4 Data / Factory Reset, How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 1, imagem 1 %32 How to Wipe Samsung Galaxy S4 Data / Factory Reset, How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 1, imagem 2 %32
    • Turn off the phone. Press and hold at the same time Volume UP,Home and Power keys. When you see Galaxy logo release the Power key but continue to hold the Volume Up key and the Home key.
  2. How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 2, imagem 1 %32 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 2, imagem 2 %32 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 2, imagem 3 %32
    • Release them when the Android System Recovery screen appears. Use Volume Up/Down keys for navigation and Power On key for OK. Choose "wipe cache partition", "Yes -- delete all user data", "reboot system now".
  3. How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 3, imagem 1 %32 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 3, imagem 2 %32 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 3, imagem 3 %32
    • That's all.
    • Did you do it successfully?
Conclusão
This guide does not require resassembly.
283 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
194.093 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
327 Membros
Autoria de 1.699 guias
29 comentários
Here my recommendation is a data eraser named Android Data Eraser, which can erase all Android data including contacts, messages, call history, apps, system setting, photo, video, etc. Indeed, Android Data Eraser worth trusting and it makes the work more effective. What you need is a windows computer. One single click and data deletion finish.
http://www.recover-iphone-android.com/er...
yisdddcbrown - Responder
easy to follow instructions but does not work have done it 3 times now and get to a step which requires to do a factory reset. Phone the automatically switches off and loses connection with program and have to start all over again. Goes round in circles with a factory reset the only result - and you can do that without downloading the program.
maser222e -
why would you bother when you can factory reset in 1 min???
rickialison -
Deleted data from samsung phone are recoverable with Coolmuster Samsung Recovery software. But you need to follow special steps as droid phone`s memory is not accessible easily.
http://www.samsung-recovery.net/
Swolsteedd - Responder
Hi Can the software recover my calendar after I mistakenly did a factory wipe?
Helene Zinberg -
Comentar
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 96
Últimos 30 dias: 412
Ao todo: 1,128,771
