Ir para o conteúdo principal
How to Wash and Dry a Patagonia Pack
O que você precisa
  1. How to Wash and Dry a Patagonia Pack, Prepare the pack: passo 1, imagem 1 %32 How to Wash and Dry a Patagonia Pack, Prepare the pack: passo 1, imagem 2 %32 How to Wash and Dry a Patagonia Pack, Prepare the pack: passo 1, imagem 3 %32
    • Open the pack and remove all contents.
    • Double-check every pocket—you never know what treasures or love notes might be hiding!
    • Shake out loose dirt and debris from the main compartment.
    • Open all pockets and smaller sections, then shake or brush out any remaining debris in those areas.
  2. How to Wash and Dry a Patagonia Pack: passo 2, imagem 1 %32 How to Wash and Dry a Patagonia Pack: passo 2, imagem 2 %32 How to Wash and Dry a Patagonia Pack: passo 2, imagem 3 %32
    • Loosen all drawcords and cinches.
    • Flip the pack inside-out.
    • It might feel awkward, but don’t worry—packs are manufactured inside-out and can handle it!
    • Wipe or brush away any debris revealed during the flip. Pay special attention to the bottom corners and under binding tape where lint tends to collect.
    • Use a soft, dry brush to reach into tight crevices.
  3. How to Wash and Dry a Patagonia Pack, Spot clean: passo 3, imagem 1 %32 How to Wash and Dry a Patagonia Pack, Spot clean: passo 3, imagem 2 %32 How to Wash and Dry a Patagonia Pack, Spot clean: passo 3, imagem 3 %32
    • Mix a small amount of dish soap with warm water.
    • Use a soft brush to pre-treat any tough stains with the soapy water mixture.
    • Focus on shoulder straps, back panels, and bottom panels—these areas tend to collect the most grime.
    • See Spot Clean Technical Gear for more details.
  4. How to Wash and Dry a Patagonia Pack, Hand wash (For foam-backed packs): passo 4, imagem 1 %32 How to Wash and Dry a Patagonia Pack, Hand wash (For foam-backed packs): passo 4, imagem 2 %32 How to Wash and Dry a Patagonia Pack, Hand wash (For foam-backed packs): passo 4, imagem 3 %32
    • If your pack has integrated foam pieces, like a foam back, you must wash it by hand. For packs without foam, you can skip to Step 8 for machine washing directions.
    • Fill a tub or sink with warm water and add a biodegradable soap or detergent.
    • Any biodegradable liquid detergent free of dye will work. Look for labels like "organic" or "sensitive skin."
    • Submerge the pack and gently scrub it with a soft brush or sponge, paying extra attention to dirty or stained areas.
    • Flip the pack inside-out and right-side-out as needed to reach all areas.
  5. How to Wash and Dry a Patagonia Pack, Rinse: passo 5, imagem 1 %32 How to Wash and Dry a Patagonia Pack, Rinse: passo 5, imagem 2 %32
    • Drain the dirty water.
    • Make sure you used biodegradable soap before dumping outside!
    • Rinse the backpack thoroughly with clean, cool water until all soap is gone.
    • If you're outside, a hose works great for this step!
  6. How to Wash and Dry a Patagonia Pack, Hang to dry: passo 6, imagem 1 %32
    • Flip the pack right-side-out so it dries in its natural shape.
    • Shake out excess water, especially from compartments where it can pool.
    • Hang the pack upside down to dry in a well-ventilated area, out of direct sunlight.
  7. How to Wash and Dry a Patagonia Pack, All done!: passo 7, imagem 1 %32 How to Wash and Dry a Patagonia Pack, All done!: passo 7, imagem 2 %32
    • You did it!
    • Your pack is fresh and ready for more adventures.
    • Maybe vow to keep coffee mugs out of it next time 😉
  8. How to Wash and Dry a Patagonia Pack, Machine wash (For packs without foam): passo 8, imagem 1 %32 How to Wash and Dry a Patagonia Pack, Machine wash (For packs without foam): passo 8, imagem 2 %32 How to Wash and Dry a Patagonia Pack, Machine wash (For packs without foam): passo 8, imagem 3 %32
    • Only machine wash packs without foam. If your pack has integrated foam, see Step 4 for hand washing instructions.
    • The pictured item is a Black Hole® Cube but other examples include some Lightweight Travel Totes, cotton tote, and the Slope Runner Vest.
    • Some bags also have removable foam that can be taken out before machine washing.
    • Spot clean first with dish soap and warm water. See Spot Clean Technical Gear.
    • Open all zippers and loosen all cinches to allow for water flow. Fasten all buckles to prevent damage.
    • Wash inside-out if the interior is dirtier; right-side-out if the exterior needs more attention.
  9. How to Wash and Dry a Patagonia Pack: passo 9, imagem 1 %32 How to Wash and Dry a Patagonia Pack: passo 9, imagem 2 %32 How to Wash and Dry a Patagonia Pack: passo 9, imagem 3 %32
    • Use a front-loading machine or top-loading machine without an agitator (the central spindle). Agitators can damage packs by causing tangles, tears, or scrapes.
    • Place the pack in the washing machine with gentle, biodegradable laundry detergent.
    • Set the load size to small.
    • Set the water temperature to cold or warm.
    • Set the wash cycle to normal or gentle/delicate/permanent press.
    • Set the spin cycle to low or off.
    • Start the washing machine.
  10. How to Wash and Dry a Patagonia Pack, Hang to dry: passo 10, imagem 1 %32 How to Wash and Dry a Patagonia Pack, Hang to dry: passo 10, imagem 2 %32
    • Hang the pack right-side-out in a well-ventilated, shaded area to air dry.
    • Don't put the pack in the dryer.
    • Zippers last longer when they’re clean, dry, and free of debris or corrosive agents like saltwater, sweat, or toiletries.
    • Avoid using zipper lubricants unless absolutely necessary. If a clean zipper is still sticky, it may need to be sent in for repair.
    • Exception: Waterproof zippers on submersible packs require specific lubricants—check the manufacturer’s recommendations.
Linha de Chegada
Zach Mueller
Membro desde: 02/23/23
1.762 Reputação
Autoria de 9 guias
Equipe
Patagonia Membro de Patagonia
Community
9 Membros
Autoria de 138 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 102
Ao todo: 509
