Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay your jacket out and zip up all the zippers.
If your jacket has hook-and-loop tape, fasten it closed.
Place the jacket in your washing machine.
Add technical wash specifically designed for down garments.
Set the load size on the washing machine to small.
Set the water temperature on the washing machine to cold/cold.
Run the washing machine on a gentle or normal wash cycle.
Leave the jacket in the washing machine and run the rinse cycle a second time.
Remove the jacket from the washing machine and place it in the dryer.
Add a couple of tennis balls to the dryer.
Set the dryer on a low-heat setting with a normal dry-cycle time.
Start the dryer.
12 outras pessoas executaram este guia.
3 comentários
Inexpensive and warm down jackets have long since become part of our wardrobe. And almost every jacket has a warning label prohibiting wash and dry it at home.But enterprising housewives long found a way to wash down jackets at home. It turns out that it is not so difficult if you know some tricks. Here you will find tips how to wash down jacket in the washing machine and by hand https://pinkycloud.com/how-to-wash-a-dow....
It is also very important to know how to store down jackets, it very much depends on how long you will wear it http://triplefatgoose.com/blog/how-to-ta... Here are details and even more
