Ir para o conteúdo principal
How to Use the Soldering Splint
O que você precisa
  1. How to Use the Soldering Splint, Twist the wires together: passo 1, imagem 1 %32 How to Use the Soldering Splint, Twist the wires together: passo 1, imagem 2 %32 How to Use the Soldering Splint, Twist the wires together: passo 1, imagem 3 %32
    • Even though the solder will bond your wires together, intertwining the wires beforehand will create more surface area, allowing for a stronger bond.
    • Twist the wires together. If the wires will be under strain, consider twisting them into a Western Union splice.
  2. How to Use the Soldering Splint, Secure the wires in the soldering splint: passo 2, imagem 1 %32 How to Use the Soldering Splint, Secure the wires in the soldering splint: passo 2, imagem 2 %32 How to Use the Soldering Splint, Secure the wires in the soldering splint: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Soldering Splint
    $9.95
    • Center the wire splice between the jaws.
    • Use your fingers or the flat end of a spudger to press one end of the splice into a jaw.
    • Be gentle if you're manipulating thin wires to prevent accidental breakage.
    • Press the remaining end into the other jaw.
  3. How to Use the Soldering Splint, Solder the wires: passo 3, imagem 1 %32 How to Use the Soldering Splint, Solder the wires: passo 3, imagem 2 %32 How to Use the Soldering Splint, Solder the wires: passo 3, imagem 3 %32
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Your splice is secured in place! Use your preferred tool to solder the splice.
    • Make sure the solder fully saturates the splice. If the solder doesn't flow into the splice, apply flux to the splice and try again. If the flux didn't help, you may need to turn up the soldering iron temperature.
Conclusão
For more soldering guides and tips, click here.
Do you have soldering questions? Check out our Answers community!
5 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
309.769 Reputação
Autoria de 701 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.618 guias
1Comentário do guia
Don’t twist the wires together, clean them with IPA, tin the wires and lap solder or do a hook and loop or a lap/lash splice. David, Master IPC trainer
David - Responder
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 78
Últimos 30 dias: 352
Ao todo: 7,079
