Introdução
Use this video guide to upgrade CPU Core i5 to Core i7 on your iMac 27" Retina 5K Display (Late 2014 & 2015).
O que você precisa
Instruções em vídeo
Quase terminado!
To reassemble your device, follow these instructions.
Conclusão
6 outras pessoas executaram este guia.
3 comentários
The method you use to remove the screen is very dangerous but the guide is helpful.
PJVCC - Responder
Good tutorial also useful to replace the SSD blade.
I would not change the processor and leave the creepy fusion drive, but
save the data, split the fusion drive, replace the SSD blade with a decent NVMe SSD (e.g. 512GB) to hold the OS and programs.
You may keep the HDD for your mass data or replace it with a SSD too.
The NVMe blade is however ways faster...
Laszlo Lebrun - Responder
Buenas noches, una pregunta, para una imac 5k 2017, con i5 7500, que procesadores le puedo poner si trae el socket 1151
Markuz Lirioz - Responder
