Introdução
This guide is catered to those with a shower drain that is not functioning properly.
If your drain is not collecting any water at a brisk pace, it is most likely clogged up in some fashion. It is most beneficial to have all of the included materials for best performance possible. Luckily for this specific guide, mechanical work is completely optional; it is all hands on with minimal risk.
O que você precisa
Gloves are optional should you desire them. They may help to keep yourself as clean as possible.
Take out your pump and a container full of warm water.
Extract water from your container and exert pressure into the drain to clean it out.
Repeat step a few times, and then test the status of your drain by starting up your bath tub and seeing if water flows naturally down the drain.
If everything goes as planned, your bath tub drain should be of good use again!
