Ir para o conteúdo principal
How to Unclog a Samsung WF350ANR Washing Machine Filter
O que você precisa
  1. How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 1, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 1, imagem 2 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 1, imagem 3 %32
    • Caution: Before beginning this guide, be sure to turn the washing machine off and unplug it from the outlet.
    • The water filter is typically located at the bottom right or bottom left. In this case, it is located at the bottom right.
    • Place a bucket under the water filter to capture excess water before moving on to the next steps.
  2. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 2, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 2, imagem 2 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 2, imagem 3 %32
    • Jiggle the water filter compartment while pulling it towards yourself to remove the compartment.
  3. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 3, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 3, imagem 2 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 3, imagem 3 %32
    • To open the water filter, move the knob to the left with your hand.
    • With your other hand, hold the bucket underneath the filter to capture the excess water.
  4. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 4, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 4, imagem 2 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 4, imagem 3 %32
    • Remove the water filter.
    • Clean hard-to-reach places in the filter with a toothbrush and excess water that was captured with the bucket.
  5. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 5, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 5, imagem 2 %32
    • Use the toothbrush to clean the slot in the washing machine where the water filter is inserted.
  6. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 6, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 6, imagem 2 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 6, imagem 3 %32
    • Inspect the inside to make sure there is no leftover lint or unnecessary objects that can clog the water filter.
  7. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 7, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 7, imagem 2 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 7, imagem 3 %32
    • Place the water filter back into the washing machine.
    • Turn the filter to the right to tighten it.
  8. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 8, imagem 1 %32 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 8, imagem 2 %32
    • Pour the bucket of excess water down a drain.
    • If a lot of lint or hair was cleaned out of the water filter, make sure to grab it with one hand as you drain out the water with the other hand.
    • Discard the lint and hair in the trash.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jasmine Andrade
Membro desde: 04/11/21
181 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 53
Duração total: 1,211
