Ir para o conteúdo principal
How to Unclog a Keurig K-Classic Coffee Maker
O que você precisa
  1. How to Unclog a Keurig K-Classic Coffee Maker, How to Unclog a Keurig K-Classic Coffee Maker: passo 1, imagem 1 %32 How to Unclog a Keurig K-Classic Coffee Maker, How to Unclog a Keurig K-Classic Coffee Maker: passo 1, imagem 2 %32
    • Unplug the Keurig and take off the water reservoir.
  2. How to Unclog a Keurig K-Classic Coffee Maker: passo 2, imagem 1 %32 How to Unclog a Keurig K-Classic Coffee Maker: passo 2, imagem 2 %32
    • Empty out the water reservoir, then remove the water filter.
  3. How to Unclog a Keurig K-Classic Coffee Maker: passo 3, imagem 1 %32
    • Use a bobby pin to clean the bottom of the dispenser.
  4. How to Unclog a Keurig K-Classic Coffee Maker: passo 4, imagem 1 %32 How to Unclog a Keurig K-Classic Coffee Maker: passo 4, imagem 2 %32
    • Fill the water reservoir about halfway with white vinegar, then fill the rest of the water reservoir with water.
  5. How to Unclog a Keurig K-Classic Coffee Maker: passo 5, imagem 1 %32
    • Plug in the machine and run without a K-cup, then start brewing.
  6. How to Unclog a Keurig K-Classic Coffee Maker: passo 6, imagem 1 %32
    • Let the machine rest for 45 minutes to soak.
    • The power can be left on.
  7. How to Unclog a Keurig K-Classic Coffee Maker: passo 7, imagem 1 %32
    • Remove the water reservoir and rinse out with fresh water to remove any leftover vinegar.
  8. How to Unclog a Keurig K-Classic Coffee Maker: passo 8, imagem 1 %32
    • Place the water filter back in the water reservoir.
    • Place the lid back on top of the water reservoir, and insert entire part back on the Keurig.
Linha de Chegada
Addison Gordon
Membro desde: 10/30/20
205 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S9-G3, Cowan Fall 2020 Membro de Texas Tech, Team S9-G3, Cowan Fall 2020
TTU-COWAN-F20S9G3
Membros da 2
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 34
Duração total: 2,130
