Ir para o conteúdo principal
How to Unclog a Keurig K-Classic Coffee Maker
O que você precisa
  1. How to Unclog a Keurig K-Classic Coffee Maker, How to Unclog a Keurig K-Classic Coffee Maker: passo 1, imagem 1 %32 How to Unclog a Keurig K-Classic Coffee Maker, How to Unclog a Keurig K-Classic Coffee Maker: passo 1, imagem 2 %32
    • Unplug the Keurig and take off the water reservoir.
  2. How to Unclog a Keurig K-Classic Coffee Maker: passo 2, imagem 1 %32 How to Unclog a Keurig K-Classic Coffee Maker: passo 2, imagem 2 %32
    • Empty out the water reservoir, then remove the water filter.
  3. How to Unclog a Keurig K-Classic Coffee Maker: passo 3, imagem 1 %32
    • Use a bobby pin to clean the bottom of the dispenser.
  4. How to Unclog a Keurig K-Classic Coffee Maker: passo 4, imagem 1 %32 How to Unclog a Keurig K-Classic Coffee Maker: passo 4, imagem 2 %32
    • Fill the water reservoir about halfway with white vinegar, then fill the rest of the water reservoir with water.
  5. How to Unclog a Keurig K-Classic Coffee Maker: passo 5, imagem 1 %32
    • Plug in the machine and run without a K-cup, then start brewing.
  6. How to Unclog a Keurig K-Classic Coffee Maker: passo 6, imagem 1 %32
    • Let the machine rest for 45 minutes to soak.
    • The power can be left on.
  7. How to Unclog a Keurig K-Classic Coffee Maker: passo 7, imagem 1 %32
    • Remove the water reservoir and rinse out with fresh water to remove any leftover vinegar.
  8. How to Unclog a Keurig K-Classic Coffee Maker: passo 8, imagem 1 %32
    • Place the water filter back in the water reservoir.
    • Place the lid back on top of the water reservoir, and insert entire part back on the Keurig.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Addison Gordon
Membro desde: 10/30/20
181 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S9-G3, Cowan Fall 2020 Membro de Texas Tech, Team S9-G3, Cowan Fall 2020
TTU-COWAN-F20S9G3
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 36
Duração total: 1,851
