Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Test your tube. Use a 35ml plunger to test your tube, just to confirm it is clogged.
Massage the tube. Roll the tubing in between your fingers and “massage” it.
Switch to a smaller plunger. Start using a 10ml plunger.
Flush hot water. Fill your 10ml plunger (and extension tubing, if applicable) with hot water. As hot as you can safely tolerate. Use this to flush your tube.
Pulsate. Pulsate the 10ml plunger back and forth, in quick motion. This helps to dismantle the clog.
Flush a combination of hot water and meat tenderizer. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with a combination of hot water and meat tenderizer.
Pulsate. Pulsate the 10ml plunger once again, in a quick motion.
Flush Coca-Cola. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with Coca-Cola. Flush your tube.
Pulsate, then let Coca-Cola sit. Pulsate the 10ml plunger once again, in a quick motion. If the clog persists, allow the Coke to sit in your tube.
