Ir para o conteúdo principal
How to Unclog Epson Workforce 2760 Ink Heads
O que você precisa
  1. How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: passo 1, imagem 1 %32 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: passo 1, imagem 2 %32 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: passo 1, imagem 3 %32
    • In the "Settings" menu, set the printer cartridges to "Replace ink cartridges."
  2. How to Unclog Epson Workforce 2760 Ink Heads: passo 2, imagem 1 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 2, imagem 2 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 2, imagem 3 %32
    • Move the cartridge to the side.
    • Place a towel underneath.
  3. How to Unclog Epson Workforce 2760 Ink Heads: passo 3, imagem 1 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 3, imagem 2 %32
    • Place the cleaning solution of 100 mL in a cup of hot boiling water, with the cap off to avoid air pressure that can damage the solution.
  4. How to Unclog Epson Workforce 2760 Ink Heads: passo 4, imagem 1 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 4, imagem 2 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 4, imagem 3 %32
    • Pull 5 mL of the hot solution using the syringe.
    • Apply the solution to the black printer head first.
    • After applying the solution, wait one hour for the solution to break down the dried ink.
  5. How to Unclog Epson Workforce 2760 Ink Heads: passo 5, imagem 1 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 5, imagem 2 %32 How to Unclog Epson Workforce 2760 Ink Heads: passo 5, imagem 3 %32
    • After one hour, repeat steps one through four on the other ink heads.
    • Move the ink slot back into place, and insert the new ink cartridges.
    • Under "Settings," finish replacing ink cartridges process.
    • Print a "test page" and if the results shown on image three appear, the printer heads are successfully unclogged.
Linha de Chegada
Cristian Rodriguez
Membro desde: 10/26/22
253 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membro de CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 51
Ao todo: 661
