Ir para o conteúdo principal
How to Turn a Loop - Eye Pin Technique
O que você precisa
  1. How to Turn a Loop - Eye Pin Technique, Thread and Bend: passo 1, imagem 1 %32
    • Thread a bead onto your eye pin.
    • Using your chain nose pliers, make a 90 degree bend just above your bead.
  2. How to Turn a Loop - Eye Pin Technique, Remove Excess Pin Tail: passo 2, imagem 1 %32
    • Use side cutters to cut the wire, leaving a tail that's about one third of an inch long.
  3. How to Turn a Loop - Eye Pin Technique, Turn the Loop: passo 3, imagem 1 %32
    • Position your round nose pliers at the end of the tail, making sure the tail faces away from your body. Wrap the wire towards you to create a loop.
  4. How to Turn a Loop - Eye Pin Technique, Align Loops: passo 4, imagem 1 %32
    • When making a link like this you'll want both loops to face the same direction. To do this, grip each loop with a pair of chain nose pliers and just twist until your loops are where you want them.
  5. How to Turn a Loop - Eye Pin Technique, Opening and Closing the Loop: passo 5, imagem 1 %32
    • To open and close the loop, you can use chain nose pliers and gently twist it open from side to side.
Conclusão
Practicing these steps will help you to get the loop tight against the bead, and the loop size consistent.
Uma outra pessoa concluiu este guia.
Shaun Harrington
Membro desde: 11/25/17
176 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 49
Duração total: 1,501
