Ir para o conteúdo principal
How to Tighten the Nishiki Aero II Chain
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: passo 1, imagem 1 %32
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: passo 2, imagem 1 %32 How to Tighten the Nishiki Aero II Chain: passo 2, imagem 2 %32 How to Tighten the Nishiki Aero II Chain: passo 2, imagem 3 %32
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: passo 3, imagem 1 %32
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: passo 4, imagem 1 %32
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
Conclusão
Tobias Elder
Membro desde: 04/25/13
113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-53, Johann Spring 2013 Membro de Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 1,380
