Ir para o conteúdo principal
How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model
O que você precisa
  1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 1, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 1, imagem 2 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 1, imagem 3 %32
    • Unlock the brake barrel adjusters fasteners with a flathead screwdriver in the clockwise direction.
    • Loosening the fasteners will help to loosen the barrel in Step 2.
  2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 2, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 2, imagem 2 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 2, imagem 3 %32
    • Twist in the clockwise direction to tighten the barrel adjusters.
  3. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 3, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 3, imagem 2 %32
    • While squeezing the bike brake check the distance between the brake handle and the bike handle using a measuring device.
    • It should be about an inch if properly tightened.
    • The second image has a loose brake. The distance is less than an inch, where it should be more than an inch (reference step 8 for the right distance). This indicates that the brake is still loose.
  4. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 4, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 4, imagem 2 %32
    • Prepare for the next few steps by loosening the bike brake barrel adjuster if it is fully tightened by turning it clockwise a few times.
    • Start by squeezing the brake arms together as much as possible.
  5. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 5, imagem 1 %32
    • While maintaining the position of the brake arms from Step 4, loosen the bolt that secures the cable clamp using a 5mm Allen Wrench and turn it counter clockwise.
    • Loosen the bolt until the cable can be adjusted easily by hand.
  6. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 6, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 6, imagem 2 %32
    • While keeping the bike brake arms in the same position as described in Step 5, pull the brake cable to adjust the distance between the brake pads and the wheel.
    • Stop pulling when the brake pads are one or two millimeters away from the wheel.
  7. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 7, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 7, imagem 2 %32
    • With the brake arms still squeezed together, use the 5 mm Allen wrench to tighten the cable clamp by turning the wrench in a clockwise direction.
  8. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 8, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 8, imagem 2 %32
    • Tighten the brake barrel adjusters again (as seen in step 2). Do this until the brake handle reaches 25.4 mm from the handle when squeezing.
    • When tightening the brakes, ensure that the brake pads never touch the side of the wheel. If this occurs, then the brake cable was pulled too tight in Step 6 and needs to be loosened.
  9. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 9, imagem 1 %32 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: passo 9, imagem 2 %32
    • Finally, use the flathead screwdriver to lock the barrel adjuster fastener. Use the screwdriver to twist the fastener in a counterclockwise direction until it is tight.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Arana
Membro desde: 04/19/23
169 Reputação
Autoria de 1 guia
Equipe
UCD-MORRIS-S23S1G1 Membro de UCD-MORRIS-S23S1G1
Community
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 164
