Ir para o conteúdo principal
How to Tie a Tie: Pratt
O que você precisa
  1. How to Tie a Tie: Pratt, Preparation: passo 1, imagem 1 %32
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Pratt: passo 2, imagem 1 %32
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Pratt, Tying: passo 3, imagem 1 %32
    • Take the active end and cross it under the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Pratt: passo 4, imagem 1 %32
    • Lift the active end up, so that it is now pointing up.
  5. How to Tie a Tie: Pratt: passo 5, imagem 1 %32 How to Tie a Tie: Pratt: passo 5, imagem 2 %32
    • Pull the active end down through the loop around your neck, so that it is now pointing down and to the left.
  6. How to Tie a Tie: Pratt: passo 6, imagem 1 %32
    • Cross the active end over the front of the knot, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 8.
  7. How to Tie a Tie: Pratt: passo 7, imagem 1 %32
    • Pull the active end up through the neck loop, so that it is now pointing up.
  8. How to Tie a Tie: Pratt: passo 8, imagem 1 %32 How to Tie a Tie: Pratt: passo 8, imagem 2 %32
    • Pull the active end down through the wrap you created in step 6 (see second picture).
  9. How to Tie a Tie: Pratt, Finishing: passo 9, imagem 1 %32
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  10. How to Tie a Tie: Pratt: passo 10, imagem 1 %32
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  11. How to Tie a Tie: Pratt: passo 11, imagem 1 %32
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Conclusão
Congratulations! You've successfully tied the Pratt knot!
3 outras pessoas executaram este guia.
Wes
Membro desde: 03/29/17
535 Reputação
Autoria de 2 guias
Equipe
The Electric Warthogs Membro de The Electric Warthogs
Community
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 860
