Ir para o conteúdo principal
How to Test Speakers and Wires
O que você precisa
  1. How to Test Speakers and Wires, How to Test Speakers and Wires: passo 1, imagem 1 %32 How to Test Speakers and Wires, How to Test Speakers and Wires: passo 1, imagem 2 %32
    • Speaker Testing Option 1: Connect a 9 Volt battery to the leads of the speaker, positive lead to positive battery end and negative lead to negative battery end.
    • If a pulse is generated in the speaker then the speaker is still functioning properly.
    • This same practice would apply to the tweeter speaker as well.
    • Do not keep the 9 Volt battery connected to speaker for an extended period. It could cause damage to the speaker.
  2. How to Test Speakers and Wires: passo 2, imagem 1 %32
    • Speaker Testing Option 2: This option requires the use of a digital multimeter that has a continuity setting.
    • This setting is typically found under the resistance setting but may have its own setting as shown in the picture.
  3. How to Test Speakers and Wires: passo 3, imagem 1 %32
    • To test the continuity of the wires themselves and both ends of a single wire and test the continuity.
    • Connect each end of the single wire to the positive and negative leads of the multimeter. If there is an unbroken circuit through the speaker there will be a continuous tone output from the multimeter and/or the meter will not read "OL" (open).
  4. How to Test Speakers and Wires: passo 4, imagem 1 %32
    • Connect both ends of the speaker to the positive and negative leads of the multimeter. If there is an unbroken circuit through the speaker there will be a continuous tone output from the multimeter and/or the meter will not read "OL" (open).
  5. How to Test Speakers and Wires: passo 5, imagem 1 %32 How to Test Speakers and Wires: passo 5, imagem 2 %32
    • Capacitor Testing: This will require a digital multimeter with a capacitance testing option.
    • Connect the positive lead of the multimeter to the positive lead of the capacitor, and vice versa for the negative. If the capacitor is functioning the multimeter will give a reading that is similar to the ratings given on the capacitor casing.
    • NOTE: If the capacitor reading is -5% of its given base rating then the capacitor is consider bad.
Conclusão
17 outras pessoas executaram este guia.
Dallas
Membro desde: 10/10/16
919 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-2, Baechle Fall 2016 Membro de IUPUI, Team 3-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G2
4 Membros
Autoria de 10 guias
6Comentários do guia
Would you carry out the same procedure for Beat Solo headphones? The right side works ok, there is no sound from the left side. There is continuity throughout the left circuit.
Roy Saxby - Responder
Would this be the same procedure for Beat Solo headphones? There is no sound from the left earpiece but sound from the right side. There is continuity throughout the left side circuit. The connecting cable is also fully serviceable.
what if your speaker is from the late 1920s and has 4 wires?
John Henry - Responder
Thank you, found the problem with my subwoofer and managed to fix it with this info.
TdG - Responder
C'è un errore all inizio del servizio i poli sono tutti positivi ????????!!!!!!
Stefano serra - Responder
Comentar
Visualizações:
Últimas 24 horas: 62
Últimos 7 dias: 414
Últimos 30 dias: 2,225
Ao todo: 308,265
