Ir para o conteúdo principal
How to Take in a Dress by Hand
O que você precisa
  1. How to Take in a Dress by Hand, How to Take in a Dress by Hand: passo 1, imagem 1 %32
    • Lay the dress flat on a table.
  2. How to Take in a Dress by Hand: passo 2, imagem 1 %32 How to Take in a Dress by Hand: passo 2, imagem 2 %32
    • Measure the bust and waist of the dress with the measuring tape and write the measurements down.
    • Measure your own bust and waist. Subtract the your measurements from the dress measurements.
    • Divide these numbers by two.
    • This is the amount of fabric that will be removed from each side.
  3. How to Take in a Dress by Hand: passo 3, imagem 1 %32
    • Turn the dress inside out.
    • Use the marker to mark the amount of bust and waist fabric that you are taking in for both sides.
  4. How to Take in a Dress by Hand: passo 4, imagem 1 %32
    • Connect the marks with sewing pins (or safety pins) to make a clear path to sew along.
  5. How to Take in a Dress by Hand: passo 5, imagem 1 %32 How to Take in a Dress by Hand: passo 5, imagem 2 %32 How to Take in a Dress by Hand: passo 5, imagem 3 %32
    • Thread the needle and leave plenty of excess thread for tying knots.
    • Start at the bottom of the new hem and weave the needle in and out of the dress until you reach the other side.
    • Tie a few knots at the end and cut the excess thread.
    • Now the new hem has been made.
  6. How to Take in a Dress by Hand: passo 6, imagem 1 %32 How to Take in a Dress by Hand: passo 6, imagem 2 %32 How to Take in a Dress by Hand: passo 6, imagem 3 %32
    • Cut off the excess fabric with the fabric scissors. Stay about a centimeter away from the sewed line to make sure you do not cut the thread.
  7. How to Take in a Dress by Hand: passo 7, imagem 1 %32 How to Take in a Dress by Hand: passo 7, imagem 2 %32
    • Repeat all of the previous steps on the other side of the dress.
    • Turn your dress inside right, and that completes this guide.
Linha de Chegada
Olivia Collins
Membro desde: 03/23/21
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 71
Últimos 30 dias: 323
Duração total: 8,059
