Ir para o conteúdo principal
How to Tailor Your Pants
O que você precisa
  1. How to Tailor Your Pants, How to Tailor Your Pants: passo 1, imagem 1 %32
    • To make the process of tailoring your pants easier, use a second pair of pants that already has the desired length as an outline.
    • Place the pants with the length you want on top of the pants that you will be tailoring.
  2. How to Tailor Your Pants: passo 2, imagem 1 %32
    • Measure the length you want to cut off with your fingers.
    • The amount of fingers you use may vary depending on the length you want to cut off.
  3. How to Tailor Your Pants: passo 3, imagem 1 %32
    • Pin your pants at the length you want to cut off.
    • An alternative option to pinning your pants is marking the length with a pencil.
  4. How to Tailor Your Pants: passo 4, imagem 1 %32
    • Cut along the pins.
    • Cut along the pencil mark if you chose this option instead.
  5. How to Tailor Your Pants: passo 5, imagem 1 %32
    • Fold the pants so that the seam is on the inside. Next, sew along the folded edge with a sewing machine.
    • Pin the pants to keep the fold in place and to make sewing easier.
  6. How to Tailor Your Pants: passo 6, imagem 1 %32
    • Check to make sure your pants are now your desired length.
  7. How to Tailor Your Pants: passo 7, imagem 1 %32
    • If you have achieved your desired length then you are finished!
Conclusão
You finally finished sewing your jeans so now you can enjoy wearing them :)
Exlexis Archouletta
Membro desde: 10/20/20
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 539
