Ir para o conteúdo principal
How to Stabilize the Stem of a Longwise ES06 E-Scooter
O que você precisa
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 1, imagem 1 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 1, imagem 2 %32
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 2, imagem 1 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 2, imagem 2 %32
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 3, imagem 1 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 3, imagem 2 %32
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 4, imagem 1 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 4, imagem 2 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 4, imagem 3 %32
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 5, imagem 1 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 5, imagem 2 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 5, imagem 3 %32
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 6, imagem 1 %32 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 6, imagem 2 %32
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Conclusão
Uma outra pessoa concluiu este guia.
Maithili Admane
Membro desde: 09/24/22
145 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 46
Ao todo: 1,313
