Ir para o conteúdo principal
How to Shrink a Tennis Racket Grip
O que você precisa
  1. How to Shrink a Tennis Racket Grip, Remove Grip Tape: passo 1, imagem 1 %32
    • Pull the tape until it comes off of the grip.
    • Use a sharp object to cut it off if needed.
  2. How to Shrink a Tennis Racket Grip, Remove the Overgrip: passo 2, imagem 1 %32 How to Shrink a Tennis Racket Grip, Remove the Overgrip: passo 2, imagem 2 %32
    • If your racket does not have an overgrip on it, then skip this step.
    • There is a good chance it is sticky.
  3. How to Shrink a Tennis Racket Grip, Put the Overgrip at the Bottom of the Handle: passo 3, imagem 1 %32
    • Attach the smaller end of the new overgrip to the bottom of the handle.
    • Wrap the overgrip around the handle, parallel to the bottom of the grip.
  4. How to Shrink a Tennis Racket Grip, Wrap the Overgrip around the Handle: passo 4, imagem 1 %32
    • Pull the grip tightly, leaving little to no open areas between the different parts of the overgrip.
    • Leave a little overlap between each row of your grip.
    • Most of your overgrip should cover the handle instead of a lower row of overgrip.
    • Make each row as close to the same size as possible.
  5. How to Shrink a Tennis Racket Grip, Put on the Tape: passo 5, imagem 1 %32 How to Shrink a Tennis Racket Grip, Put on the Tape: passo 5, imagem 2 %32
    • It should tie the end of the grip to the rest of the racket.
    • I did not cut the end of the overgrip with scissors. If you want the grip to fit better, cut the end of the overgrip off at a 45 degree angle.
Conclusão
If you decide that you want to go back to the racket grip's original size, then you need to remove the overgrip and put on a replacement grip.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 73
