Ir para o conteúdo principal
How to Shorten a Sweatshirt Using the Original Hem
O que você precisa
  1. How to Shorten a Sweatshirt Using the Original Hem, How to Shorten a Sweatshirt Using the Original Hem: passo 1, imagem 1 %32
    • Lay your crewneck on a flat surface.
  2. How to Shorten a Sweatshirt Using the Original Hem: passo 2, imagem 1 %32 How to Shorten a Sweatshirt Using the Original Hem: passo 2, imagem 2 %32
    • Find your new desired length and mark it with chalk.
    • Using your chalk mark, use a ruler to mark across the width of your crewneck.
  3. How to Shorten a Sweatshirt Using the Original Hem: passo 3, imagem 1 %32
    • Measure one inch below your desired length and mark using chalk.
  4. How to Shorten a Sweatshirt Using the Original Hem: passo 4, imagem 1 %32 How to Shorten a Sweatshirt Using the Original Hem: passo 4, imagem 2 %32
    • Cut along your newly marked line.
    • Make sure to cut one layer at a time to ensure a clean cut.
  5. How to Shorten a Sweatshirt Using the Original Hem: passo 5, imagem 1 %32
    • Using a ruler, mark 1/2 an inch up from the hem of your crewneck.
  6. How to Shorten a Sweatshirt Using the Original Hem: passo 6, imagem 1 %32
  7. How to Shorten a Sweatshirt Using the Original Hem: passo 7, imagem 1 %32
    • Flip the hem inside out and align with the cut edge of your crewneck.
    • Make sure the pieces are "good side" to "good side" by ensuring the seams are facing outward.
  8. How to Shorten a Sweatshirt Using the Original Hem: passo 8, imagem 1 %32
    • Pin both pieces together with all pins facing perpendicularly to the lines you marked.
  9. How to Shorten a Sweatshirt Using the Original Hem: passo 9, imagem 1 %32 How to Shorten a Sweatshirt Using the Original Hem: passo 9, imagem 2 %32
    • Sew one inch away from the edge, removing the pins as you go.
    • This step can also be done by hand with thread and a needle.
  10. How to Shorten a Sweatshirt Using the Original Hem: passo 10, imagem 1 %32 How to Shorten a Sweatshirt Using the Original Hem: passo 10, imagem 2 %32
    • Flip the hem right side out and admire your creation!
Linha de Chegada
Izzy DeLaGarza
Membro desde: 11/05/24
181 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-8, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 4-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G8
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 55
Últimos 30 dias: 218
Ao todo: 1,102
