Ir para o conteúdo principal
How to Shorten a Belt
O que você precisa
  1. How to Shorten a Belt, Measure the Belt: passo 1, imagem 1 %32
    • Put your belt on.
    • Using a ruler or measuring tape, measure how much of the belt you want to remove. Make this mark on the buckle end of the belt.
    • Place a mark where you will cut the belt to shorten it.
  2. How to Shorten a Belt: passo 2, imagem 1 %32 How to Shorten a Belt: passo 2, imagem 2 %32
    • Measure how much of the belt is folded over the belt. Add that length to the cut mark to leave enough material to fold over the buckle.
    • Using a screwdriver, remove all screws from the buckle end of the belt.
  3. How to Shorten a Belt: passo 3, imagem 1 %32
    • Using scissors, cut on the exact spot of your new mark.
    • You can round the edges of the cut to make the belt tip look neat.
    • You can add shoe or leather polish to the cut mark to ensure it is the same color as the belt.
  4. How to Shorten a Belt, Reassembling the Belt: passo 4, imagem 1 %32 How to Shorten a Belt, Reassembling the Belt: passo 4, imagem 2 %32 How to Shorten a Belt, Reassembling the Belt: passo 4, imagem 3 %32
    • Reinsert the screws and screw them back in place using a screwdriver.
  5. How to Shorten a Belt, Add New Buckle Holes to the Belt: passo 5, imagem 1 %32 How to Shorten a Belt, Add New Buckle Holes to the Belt: passo 5, imagem 2 %32
    • Place your belt on a workspace that can be nailed into.
    • Place a nail on the new spot where you'd like to add a hole.
    • Hammer the nail until it goes all the way through the belt.
    • Caution: Be careful when using a hammer.
  6. How to Shorten a Belt: passo 6, imagem 1 %32 How to Shorten a Belt: passo 6, imagem 2 %32
    • Try on the belt and see if it fits comfortably.
    • If not, follow this guide again to add more holes.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Uvaldo Chan
Membro desde: 04/12/21
154 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 81
Ao todo: 2,881
