Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
A whip stitch is an easy way to sew two pieces of fabric together. You can use this stitch whether the edges of the two pieces of material line up or not. If they do line up, the stitch will loop around the outside edge of the material.
O que você precisa
Align the two pieces of material you will be stitching together.
Thread your needle and tie a knot in the end of the thread.
Drive the needle into the bottom layer of material from the back side.
Slowly start to pull the thread taut. As you pull, you will see a loop form.
Draw the needle through the loop.
Pull the thread taut, forming a knot.
Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
19 outras pessoas executaram este guia.
