Ir para o conteúdo principal
How to Sew a Hole and reattach zippers to a purse
O que você precisa
  1. How to Sew a Hole and reattach zippers to a purse, Hole and Zippers: passo 1, imagem 1 %32
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. How to Sew a Hole and reattach zippers to a purse: passo 2, imagem 1 %32
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
  3. How to Sew a Hole and reattach zippers to a purse: passo 3, imagem 1 %32 How to Sew a Hole and reattach zippers to a purse: passo 3, imagem 2 %32
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
  4. How to Sew a Hole and reattach zippers to a purse: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to grab one side of the opened coil.
  5. How to Sew a Hole and reattach zippers to a purse: passo 5, imagem 1 %32
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
  6. How to Sew a Hole and reattach zippers to a purse: passo 6, imagem 1 %32
    • Place one side of the coil inside the zipper slider just a little using tweezers.
  7. How to Sew a Hole and reattach zippers to a purse: passo 7, imagem 1 %32 How to Sew a Hole and reattach zippers to a purse: passo 7, imagem 2 %32
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
  8. How to Sew a Hole and reattach zippers to a purse: passo 8, imagem 1 %32 How to Sew a Hole and reattach zippers to a purse: passo 8, imagem 2 %32
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
  9. How to Sew a Hole and reattach zippers to a purse: passo 9, imagem 1 %32 How to Sew a Hole and reattach zippers to a purse: passo 9, imagem 2 %32 How to Sew a Hole and reattach zippers to a purse: passo 9, imagem 3 %32
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
Conclusão
ReNieka Perry
Membro desde: 01/21/18
223 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 99
Duração total: 1,947
