Ir para o conteúdo principal
How to Sew a Cloth Seat Cushion Strap
O que você precisa
  1. How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: passo 1, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: passo 1, imagem 2 %32
    • Find the hole in the seat cushion.
  2. How to Sew a Cloth Seat Cushion Strap: passo 2, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 2, imagem 2 %32
    • Cut a piece of thread long enough to fit the hole.
    • Put the thread through the eye of the needle.
  3. How to Sew a Cloth Seat Cushion Strap: passo 3, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 3, imagem 2 %32
    • Tie a knot at the end of the thread.
  4. How to Sew a Cloth Seat Cushion Strap: passo 4, imagem 1 %32
    • Sandwich the strap in between the two pieces of fabric.
  5. How to Sew a Cloth Seat Cushion Strap: passo 5, imagem 1 %32
    • Push the needle from the inside of the cushion, around where the broken seam is.
  6. How to Sew a Cloth Seat Cushion Strap: passo 6, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 6, imagem 2 %32
    • Use a small stitch over the material.
    • Pull the needle until thread is taut.
  7. How to Sew a Cloth Seat Cushion Strap: passo 7, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 7, imagem 2 %32
    • Use a small stitch under the material.
    • Pull the needle until the thread is taut.
  8. How to Sew a Cloth Seat Cushion Strap: passo 8, imagem 1 %32
    • Continue the same alternating stitch pattern of over and under until the end of the hole.
  9. How to Sew a Cloth Seat Cushion Strap: passo 9, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 9, imagem 2 %32
    • Push the needle in through the end of the sewn hole.
  10. How to Sew a Cloth Seat Cushion Strap: passo 10, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 10, imagem 2 %32 How to Sew a Cloth Seat Cushion Strap: passo 10, imagem 3 %32
    • Wrap the thread around the needle two times.
    • Tie off your thread with a knot.
  11. How to Sew a Cloth Seat Cushion Strap: passo 11, imagem 1 %32
    • Pull the knot tightly.
  12. How to Sew a Cloth Seat Cushion Strap: passo 12, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 12, imagem 2 %32 How to Sew a Cloth Seat Cushion Strap: passo 12, imagem 3 %32
    • Push the needle through the side of the cushion.
  13. How to Sew a Cloth Seat Cushion Strap: passo 13, imagem 1 %32 How to Sew a Cloth Seat Cushion Strap: passo 13, imagem 2 %32
    • Pull until taut and cut off the excess thread.
    • This will hide the excess thread.
  14. How to Sew a Cloth Seat Cushion Strap: passo 14, imagem 1 %32
    • Now, your seat cushion is fixed!
Linha de Chegada
Deepa Bhat
Membro desde: 04/25/24
253 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-5, Whithaus Spring 2024 Membro de UC Davis, Team 3-5, Whithaus Spring 2024
UCD-WHITHAUS-S24S3G5
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 491
