Ir para o conteúdo principal
How to Securely Anchor and Install a Towel Rack
O que você precisa
  1. How to Securely Anchor and Install a Towel Rack, Towel Rack: passo 1, imagem 1 %32 How to Securely Anchor and Install a Towel Rack, Towel Rack: passo 1, imagem 2 %32
    • Disassemble the mounting bracket by first unscrewing the screw from its side.
  2. How to Securely Anchor and Install a Towel Rack: passo 2, imagem 1 %32
    • Place drywall anchors into the holes.
  3. How to Securely Anchor and Install a Towel Rack: passo 3, imagem 1 %32
    • Hammer the drywall anchors into the holes.
  4. How to Securely Anchor and Install a Towel Rack: passo 4, imagem 1 %32 How to Securely Anchor and Install a Towel Rack: passo 4, imagem 2 %32
    • Place the mounting bracket onto the wall making sure that the hole with "UP" next to it is aligned with the top hole. Screw in a screw through the mounting bracket into the drywall anchors.
  5. How to Securely Anchor and Install a Towel Rack: passo 5, imagem 1 %32
    • Place the cover over the base of the mounting bracket.
  6. How to Securely Anchor and Install a Towel Rack: passo 6, imagem 1 %32
    • Insert the towel rack into the hole of the towel rack holder and place the towel rack holder over the bracket.
  7. How to Securely Anchor and Install a Towel Rack: passo 7, imagem 1 %32
    • Secure the towel rack holder into the bracket by screwing the small screw from step 1 into its hole.
Linha de Chegada
Brenton Reece
Membro desde: 09/27/24
148 Reputação
Autoria de 1 guia
Equipe
CSU Sacramento, Team 1-10, Laflen Fall 2024 Membro de CSU Sacramento, Team 1-10, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G10
1 Membro
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 68
Ao todo: 461
