Ir para o conteúdo principal
How to Secure a Hook and Eye Fastener Properly
O que você precisa
  1. How to Secure a Hook and Eye Fastener Properly, How to Secure a Hook and Eye Fastener Properly: passo 1, imagem 1 %32
    • Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
    • Then thread the two ends through the eye of the needle.
  2. How to Secure a Hook and Eye Fastener Properly: passo 2, imagem 1 %32 How to Secure a Hook and Eye Fastener Properly: passo 2, imagem 2 %32
    • Slide the needle down the thread until you reach about two inches from the loop.
    • Position the needle between the loop and pull through.
    • This will create a knot at the base of the needle which will make the thread less tangled.
    • Next, pull on both ends of the thread to make them equal length before tying a knot.
  3. How to Secure a Hook and Eye Fastener Properly: passo 3, imagem 1 %32
    • First, position the hook above the zipper and on the inside fabric, about 3mm from the edge.
  4. How to Secure a Hook and Eye Fastener Properly: passo 4, imagem 1 %32 How to Secure a Hook and Eye Fastener Properly: passo 4, imagem 2 %32
    • Remove the hook and start by sewing a stitch where your hook was.
    • Then trim the extra thread close to the knot.
  5. How to Secure a Hook and Eye Fastener Properly: passo 5, imagem 1 %32 How to Secure a Hook and Eye Fastener Properly: passo 5, imagem 2 %32
    • Sew on top of the knot three times to make sure it is secure.
    • Position the hook on top of the stitch.
    • Anchor the front part of the hook down by sewing over the bottom edge of the hook three times.
  6. How to Secure a Hook and Eye Fastener Properly: passo 6, imagem 1 %32
    • Then poke the needle underneath the fabric and bring it up in one of the holes.
  7. How to Secure a Hook and Eye Fastener Properly: passo 7, imagem 1 %32 How to Secure a Hook and Eye Fastener Properly: passo 7, imagem 2 %32
    • Now hold the other eye of the hook in place.
    • The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
    • After that push, the needle through that loop and pull which create a small knot.
    • Now repeat this stitch two more times.
  8. How to Secure a Hook and Eye Fastener Properly: passo 8, imagem 1 %32
    • Then take the needle into the other hole, coming up in the center.
  9. How to Secure a Hook and Eye Fastener Properly: passo 9, imagem 1 %32
    • Then repeat step 7 for this hole.
  10. How to Secure a Hook and Eye Fastener Properly: passo 10, imagem 1 %32
    • After this, tie a knot.
    • Then cut the thread and tie a knot at the end of the thread.
  11. How to Secure a Hook and Eye Fastener Properly: passo 11, imagem 1 %32
    • To position the eyes, place the hook and eyes together and line up the fabric so the edges match.
  12. How to Secure a Hook and Eye Fastener Properly: passo 12, imagem 1 %32 How to Secure a Hook and Eye Fastener Properly: passo 12, imagem 2 %32
    • Hold it in place with your fingers. Start by stitching across the wire and trim the tail near the knot.
    • Sew on top of the knot and the wire three times to make sure it is secure.
    • Making sure you come out from the middle of the eyes.
  13. How to Secure a Hook and Eye Fastener Properly: passo 13, imagem 1 %32
    • After this, repeat step 7.
  14. How to Secure a Hook and Eye Fastener Properly: passo 14, imagem 1 %32 How to Secure a Hook and Eye Fastener Properly: passo 14, imagem 2 %32
    • Then repeat step 8 and 9.
    • It should look like this at the end.
Linha de Chegada
Cecilia
Membro desde: 05/10/21
229 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 97
Ao todo: 2,283
