Ir para o conteúdo principal
How to fix a Samsung Galaxy S5 that is not charging
O que você precisa
  1. How to fix a Samsung Galaxy S5 that is not charging, Check Charging Port: passo 1, imagem 1 %32
    • Note: Images here are from the internet for reference only but not from me
    • Check the charging port at the bottom of the phone. I used a magnifying glass with light to see because these are very small.
  2. How to fix a Samsung Galaxy S5 that is not charging, Check the pins: passo 2, imagem 1 %32
    • When I checked the pins in my phone, I saw 3. with the one on the rightmost having 2 layers. This was because one of them was bent making it look like there were only 3 instead of 4
    • I used a needle to push the bent pin. After a few pushes, it started charging again!
    • Reminder: be very careful when pushing the pins. I only did this because my phone was not charging at all and I was ready to get a replacement for the charging port if it still didn't work
Conclusão
10 outras pessoas executaram este guia.
SLomat
Membro desde: 05/16/18
360 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 56
Duração total: 6,121
