Ir para o conteúdo principal
How to Salt Scour a Cast Iron Skillet
O que você precisa
  1. How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: passo 1, imagem 1 %32 How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: passo 1, imagem 2 %32 How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: passo 1, imagem 3 %32
    • Wet the pan in hot water.
  2. How to Salt Scour a Cast Iron Skillet: passo 2, imagem 1 %32 How to Salt Scour a Cast Iron Skillet: passo 2, imagem 2 %32 How to Salt Scour a Cast Iron Skillet: passo 2, imagem 3 %32
    • Apply coarse salt and scrub the pan with a damp dish towel until the pan is stripped of rust and surface particles.
  3. How to Salt Scour a Cast Iron Skillet: passo 3, imagem 1 %32 How to Salt Scour a Cast Iron Skillet: passo 3, imagem 2 %32 How to Salt Scour a Cast Iron Skillet: passo 3, imagem 3 %32
    • Rinse off the pan in cool water and wipe dry with a new towel.
  4. How to Salt Scour a Cast Iron Skillet: passo 4, imagem 1 %32 How to Salt Scour a Cast Iron Skillet: passo 4, imagem 2 %32 How to Salt Scour a Cast Iron Skillet: passo 4, imagem 3 %32
    • Evenly apply the cooking oil spray coat to the pan and wipe away excess oil.
  5. How to Salt Scour a Cast Iron Skillet: passo 5, imagem 1 %32 How to Salt Scour a Cast Iron Skillet: passo 5, imagem 2 %32 How to Salt Scour a Cast Iron Skillet: passo 5, imagem 3 %32
    • Bake-in coating at 450 degrees Fahrenheit for one hour.
  6. How to Salt Scour a Cast Iron Skillet: passo 6, imagem 1 %32 How to Salt Scour a Cast Iron Skillet: passo 6, imagem 2 %32
    • Allow to cool for 20 minutes.
Conclusão
The steps provided in this guide have walked you through the process of salt-scouring and re-seasoning a cast iron pan. Now you are ready to cook using a fresh and clean cast-iron pan.
Repeat steps 4-6 if needed to fill in any gaps in the pan that are still bare.
Ethan
Membro desde: 02/21/23
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 243
