Ir para o conteúdo principal
How to Reupholster a Bench Cushion
O que você precisa
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, imagem 1 %32 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, imagem 2 %32 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, imagem 3 %32
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: passo 2, imagem 1 %32 How to Reupholster a Bench Cushion: passo 2, imagem 2 %32 How to Reupholster a Bench Cushion: passo 2, imagem 3 %32
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: passo 3, imagem 1 %32 How to Reupholster a Bench Cushion: passo 3, imagem 2 %32 How to Reupholster a Bench Cushion: passo 3, imagem 3 %32
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: passo 4, imagem 1 %32 How to Reupholster a Bench Cushion: passo 4, imagem 2 %32 How to Reupholster a Bench Cushion: passo 4, imagem 3 %32
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: passo 5, imagem 1 %32 How to Reupholster a Bench Cushion: passo 5, imagem 2 %32 How to Reupholster a Bench Cushion: passo 5, imagem 3 %32
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: passo 6, imagem 1 %32 How to Reupholster a Bench Cushion: passo 6, imagem 2 %32 How to Reupholster a Bench Cushion: passo 6, imagem 3 %32
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: passo 7, imagem 1 %32 How to Reupholster a Bench Cushion: passo 7, imagem 2 %32 How to Reupholster a Bench Cushion: passo 7, imagem 3 %32
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Linha de Chegada
Xochitl Vara
Membro desde: 01/26/22
169 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 719
