Ir para o conteúdo principal
How to Resurface a Fishing Lure
O que você precisa
  1. How to Resurface a Fishing Lure, How to Resurface a Fishing Lure: passo 1, imagem 1 %32
    • Evaluate the material your lures are made from. This will affect your process slightly.
  2. How to Resurface a Fishing Lure: passo 2, imagem 1 %32 How to Resurface a Fishing Lure: passo 2, imagem 2 %32
    • Remove the treble hooks and keyrings from the lure body.
    • The hooks are very sharp!
  3. How to Resurface a Fishing Lure: passo 3, imagem 1 %32 How to Resurface a Fishing Lure: passo 3, imagem 2 %32
    • Sand your lures. They can either be fully sanded or just scuffed on the surface. This helps the polyurethane bond to the surface.
    • Lures can be repainted with acrylic paints but that is out of the scope of this tutorial.
  4. How to Resurface a Fishing Lure: passo 4, imagem 1 %32 How to Resurface a Fishing Lure: passo 4, imagem 2 %32
    • Wipe the freshly sanded lures with a wet cloth. Allow it to fully dry.
  5. How to Resurface a Fishing Lure: passo 5, imagem 1 %32 How to Resurface a Fishing Lure: passo 5, imagem 2 %32
    • Tie a string to the lures and dip the lures fully into the polyurethane.
    • Do this step in a large and well ventilated space. Fumes from your polyurethane should not be inhaled.
  6. How to Resurface a Fishing Lure: passo 6, imagem 1 %32
    • Hang your lures up to dry for at least 24 hours.
Conclusão
All that is necessary after the lure's new surface has cured is to reattach the keyring and treble hooks.
Uma outra pessoa concluiu este guia.
Zach Solka
Membro desde: 03/30/16
149 Reputação
Autoria de 1 guia
Equipe
2 comentários
Looking for your first rod so you can take part in the great sport of fishing? Have you looked through some catalogs or browsed in sporting goods store and are already confused? All these new words to learn. Spinning fishing rods? Bait-casting '''fishing rods'''? Spin casting fishing rods? What do all these things mean?
mahbub_rahman - Responder
Very interesting post. Every step explains with the images are really helpful for the beginners. I love fishing in Puerto Vallarta and your post helps me a lot to resurface my fishing lure. Thanks a million and please keep up the effective work.
Marlas PV Landing - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 838
