Introdução
Cast Iron Pans are a wonderful cooking tool but they require care to function well. They can be damaged by excessive heat over extended periods of time and by the process of oxidation causing them to rust. In this guide, you will learn how to remove the damage and restore your cast iron to a “like-new” state.
O que você precisa
Soak your pan in a roughly 50/50 mix of distilled white vinegar and water for about an hour.
Conclusão
You’re all done!
