Ir para o conteúdo principal
How to Restore a Used Canvas
O que você precisa
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: passo 1, imagem 1 %32 How to Restore a Used Canvas, How to Restore a Used Canvas: passo 1, imagem 2 %32
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: passo 2, imagem 1 %32 How to Restore a Used Canvas: passo 2, imagem 2 %32
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: passo 3, imagem 1 %32
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: passo 4, imagem 1 %32 How to Restore a Used Canvas: passo 4, imagem 2 %32 How to Restore a Used Canvas: passo 4, imagem 3 %32
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: passo 5, imagem 1 %32
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: passo 6, imagem 1 %32
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: passo 7, imagem 1 %32 How to Restore a Used Canvas: passo 7, imagem 2 %32 How to Restore a Used Canvas: passo 7, imagem 3 %32
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: passo 8, imagem 1 %32 How to Restore a Used Canvas: passo 8, imagem 2 %32 How to Restore a Used Canvas: passo 8, imagem 3 %32
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
Linha de Chegada
Sandra Henriquez
Membro desde: 04/21/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 36
Duração total: 603
