Introdução
Nike Flip-Flops are a very common item in a person's wardrobe. Using these Nike Flip-Flops constantly causes wear and tear, which could be dangerous to the person wearing them. As the flip-flops tear they become unstable and can cause foot injuries like a sprained ankle. This guide will help protect you feet, by fixing the torn parts and making the Nike flip-flops more stable.
O que você precisa
Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
Gently apply the adhesive on the torn parts of the flip-flop.
Make sure the torn parts are completely covered. Overspill is okay.
Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
The Nike Flip-Flop(s) are now restored and can be worn again.
7 outras pessoas executaram este guia.
2Comentários do guia
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
Oh darn I see it now.lol
