Ir para o conteúdo principal
How to Restore a Dining Chair
O que você precisa
  1. How to Restore a Dining Chair, How to Restore a Dining Chair: passo 1, imagem 1 %32 How to Restore a Dining Chair, How to Restore a Dining Chair: passo 1, imagem 2 %32 How to Restore a Dining Chair, How to Restore a Dining Chair: passo 1, imagem 3 %32
    • Begin with an old chair frame.
    • For frames in good condition, continue to step 5.
    • Using your sandpaper, rub any marks or scuffs off the wood.
    • Always rub with the grain of the wood.
  2. How to Restore a Dining Chair: passo 2, imagem 1 %32 How to Restore a Dining Chair: passo 2, imagem 2 %32
    • Use the cleaning cloth to wipe off any excess dirt and dust.
  3. How to Restore a Dining Chair: passo 3, imagem 1 %32 How to Restore a Dining Chair: passo 3, imagem 2 %32 How to Restore a Dining Chair: passo 3, imagem 3 %32
    • Holding the spray paint 6-12 inches away from the chair, apply a light coat of paint.
    • Allow it to dry for about 5 minutes.
    • Apply a second light coat over the front of the chair and allow it to dry for 10 minutes.
  4. How to Restore a Dining Chair: passo 4, imagem 1 %32 How to Restore a Dining Chair: passo 4, imagem 2 %32
    • Flip the chair over.
    • Repeat step 3 for the back side.
  5. How to Restore a Dining Chair: passo 5, imagem 1 %32 How to Restore a Dining Chair: passo 5, imagem 2 %32 How to Restore a Dining Chair: passo 5, imagem 3 %32
    • While the paint dries, work on the seat.
    • Grab the wood board and set it down.
    • Grab the desired cushion and rest it on top of the board.
    • Make sure to align all four corners of the wood to the corners of the cushion.
  6. How to Restore a Dining Chair: passo 6, imagem 1 %32 How to Restore a Dining Chair: passo 6, imagem 2 %32 How to Restore a Dining Chair: passo 6, imagem 3 %32
    • Now grab the cushion cover.
    • You may use fabric (cut to size) instead of a cushion cover.
    • Place your cover on top of the cushion, aligning all four corners.
  7. How to Restore a Dining Chair: passo 7, imagem 1 %32 How to Restore a Dining Chair: passo 7, imagem 2 %32 How to Restore a Dining Chair: passo 7, imagem 3 %32
    • Grab the stack of wood, cushion and cover and flip it over.
    • Align them so they stack up evenly.
    • Fragments of the cushion cover may stick out a little.
  8. How to Restore a Dining Chair: passo 8, imagem 1 %32 How to Restore a Dining Chair: passo 8, imagem 2 %32 How to Restore a Dining Chair: passo 8, imagem 3 %32
    • Fold the sides of the cover over the board and cushion keeping them as close to the center of the board as possible.
    • Select a side to start on.
    • With the staple gun, staple the end of the cushion cover you are holding into the board.
    • Rotate the board and staple down the other side.
    • Continue to staple down the sides, placing staples about 1 inch apart.
    • Fold the corners in and staple them onto the board.
  9. How to Restore a Dining Chair: passo 9, imagem 1 %32 How to Restore a Dining Chair: passo 9, imagem 2 %32 How to Restore a Dining Chair: passo 9, imagem 3 %32
    • Make sure that the paint on the chair frame has completely dried up.
    • Grab your newly covered cushion and place it on the seat of the chair frame.
    • Holding on to both the cushion and the frame, flip the chair over.
  10. How to Restore a Dining Chair: passo 10, imagem 1 %32 How to Restore a Dining Chair: passo 10, imagem 2 %32 How to Restore a Dining Chair: passo 10, imagem 3 %32
    • Place the screws in the screw holes.
    • Tighten the screws with the philips screw driver.
    • To avoid the wood from cracking, do not apply to much force when turning screwdriver.
  11. How to Restore a Dining Chair: passo 11, imagem 1 %32
    • Make good use of your brand new chair.
Linha de Chegada
3 outras pessoas executaram este guia.
Chuy Mercado
Membro desde: 09/29/15
228 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-6, Green Fall 2015 Membro de Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
Membros da 5
Autoria de 4 guias
2 comentários
Do you have any Ideas on fixing a wobble chair before replacing the seat ?
Robert - Responder
Hi, I have a aoks chair I want to restore can you please help
Josefina Mejia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 6,702
