Ir para o conteúdo principal
How to Restore a Bent Chopstick
O que você precisa
  1. How to Restore a Bent Chopstick, How to Restore a Bent Chopstick: passo 1, imagem 1 %32
    • Using a deep pan, fill the bottom with water.
    • Set the heat to medium/low until the water begins to simmer, then bring the flame to low.
    • Do not bring the water to a boil.
  2. How to Restore a Bent Chopstick: passo 2, imagem 1 %32
    • Add salt into the pan, incorporating enough salt until the water is saturated. Mix until the salt dissolves.
    • The chopstick is made of a more firm plastic, so salt is necessary because the properties interact with one another to soften the plastic.
  3. How to Restore a Bent Chopstick: passo 3, imagem 1 %32 How to Restore a Bent Chopstick: passo 3, imagem 2 %32
    • Put on gloves to protect your hands from the heat, then gently add two dishes into the pan.
    • Ensure that the bowls will be able to tolerate the heat. The dishes are to help level the chopstick if your pan is not large enough to have the chopstick lie flat on the surface.
  4. How to Restore a Bent Chopstick: passo 4, imagem 1 %32
    • Insert chopstick on top of the bowls. Make sure that the curve is facing upward.
    • When readjusting the chopstick, be sure to use tongs or other tools so you don't burn your fingers.
  5. How to Restore a Bent Chopstick: passo 5, imagem 1 %32
    • Carefully take out the chopstick and gently temper by hand.
    • Be mindful of the heat when adjusting.
    • Be mindful of the strength you put into the chopstick. It may break if applying too much force.
  6. How to Restore a Bent Chopstick: passo 6, imagem 1 %32
    • Repeat Step 4 and 5 until you attain the desired results.
Conclusão
To reshape the chopstick, follow these instructions until it has straightened to satisfaction.
Uma outra pessoa concluiu este guia.
Lynne Nguyen
Membro desde: 07/28/20
160 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G10, Cardinal Summer 2020 Membro de UW Tacoma, Team S1-G10, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G10
1 Membro
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 2,735
